- 1 Sep 2006
Mouse and Kb for me, but I am not against controllers as they work smoothly for most fps games these days.
because playing against others online 16 v 16 or more, you need all the speed you can get, need to watch your back at all times. no matter how well i know a map, always wise to check behind you now and again, holding that stick down and wait for it to turn will get you kill. and auto aim! i never knew such thing existed! ha!
I hate autoaim with a passion. Being a PC gamer I naturally go for the head in FPS's, but on consoles the auto aim buggers you over so you can't really do it. Autoaim usually moves the curser to the opponents chest, well...on most of the console FPS's I have played anyway. But anyhow, it moves the cusrer towards the enemy in some way. For example, if you see an opponent moving sideways and you want to shoot just next to their head to compensate for their movement, you can't. The autoaim buggers you over again.
Controllers are just plain rubbish for aiming, hence so many console games have auto-aim. It takes far longer to spin round on a controller and there's very poor precision. While you do get better at it with practice, it never compares to a mouse.Does it get a lot easier the more one plays or is it just the nature of controllers to be harder to target the enemy?
thanks
I couldn't believe anyone could be that good without using a mouse.
And what game would that be?
PC games are made to be used with a M&K, Console games are made for a controller. Any game that's made from the ground up for a specific device works well.
Battlefield 2 on the PC is outstanding with a M&K, but Battlefield 2: Modern Combat on the Xbox360 works excellently with a controller.
The controller wouldn't work on the PC, but the M&K would feel crap on a console.
Yes but then you're gimping yourself against everyone else who has "easy" mode on.You could always go into the options and turn auto-aim off...
I'm yet to see a game where you can't.
I can't play FPS games sitting down on a sofa, it feels weird.Yep you can get good with a pad and fps can even work well with a pad, but the core mechanic of aiming is done so much better with a mouse.. its just no contest. The only advantage of a controller is so you can chill out on a sofa.
This is talking about fps of course.
You have to be quick with your movement, I am sure most people here have played in a clan on online FPS on the PC, I don't need to spell it out for you to know how quick a mouse can be use for turning and aiming and how slow (in comparison) the pad is.
It may be quicker on some games but it's more awkward to aim after having performed a fast turn.Turning in a modern console fps is probably a little quicker as they all have high acceleration these days. For other shooters I use a higher sensitivity - it all depends on the game in question.
