regarding screws for the fans...
as i mentioned to others earlier in the post you may already have some as many cases now come with a variety of screws.
you can use the the 4 included to attach front fan and then one side of the rear fan can be attached via 4 shorter screws m3.5 and then the back of that fan can be safetly attached to the back of the case using normal fan screws.
so far gaiden me and bulldog have found the corsair being postioned upside down helps by a few degrees maybe due to pressure difference i dont know.
i have 2 akasa apaches on mine in push/pull and have them attached to a akasa 3x pwm splitter which attaches to mainboard purely for rpm and temp while the fans are powered from a molex.
what i was wondering would it be better to use a proper pwm y cable straight to motherboard cpu fan header? not sure on the difference apart from one being molex powered and other mainboard powered?...
regards ...
HRhino"
No difference except the Akasa 3 way is taking the load of supplying volts to the fan off you mobo. (Basically don't change it).
I have mine mounted upside down, don't think it makes much if any difference. Idles at 31-35C depending, load 70C. Using AS3 + 2 * Scythe Kama PWM fans exhausting.
