well since nobodys replying and telling me this is okay/average temps i should be getting i may just remount it over the weekend trying the spread method however hard it may be with the paste i use thick stuff
i did one last temp/prime test today and results at default 920 speeds (turbo shows 2.8ghz 134.94x21 (using realtemp & coretemp) show the cores temps have levelled off to 58-63c on prime95 blend and mid 50's on intel burn test (max setting).
gaiden or anybody else for that matter that have a Haf932 case...would it benifit at all from installing the h5o unit exhausting out the roof as the case has 3x 120 fan points and enough room for the installation?...
just means ill remove the 230mm fan and place 2x 120mm next to the h50 unit and put a new 140mm in the place on the rear where the h50 went..
thanks
HRhino"
thanks
HRhino"
