Aye cracking kit with a bit of push/pull manages to dissipate some serious heat
Noo, Other End!exactly what i did, worked a treat
nice bit of kit
Noo, Other End!
The P180 Mini allows an epic setup with the rad mounted at the FRONT
Yes it's mine and not just the bad photograph
Noo, Other End!
To satisfy my PC OCD I need the job done proper. I'm surprised no one wants my screws though, I wasn't gonna charge for em.
Don't worry about my storage
I have two terabyte drives in the bottom two 5.25" bays with adapted adapters. The top 5.25" holds the optical drive... and the middle is all fans.
Actually so is the bottom. Almost the whole front is a powered intake.
Im getting a bit of a high pitched squeaking noise from my pc, ive stopped all the fans in turn and the noise is still there, ive put a long screwdriver against the H50 pump and listened to that but i cant hear it through there, if i tip the case on its side it stops for a bit then comes back. Has anyone else had this from their pump???
Ive got mine mounted with the logo upside down to keep it free of air.
Cheers
Dan
has any 1 fitted the h50 to an x38 ds4 i'm having problem locking the cooler in to place and i'm wodnering if its actually compatible with my motherboard. as u can see in this picture the green rin is the bracket and the red ring is what i think is stopping it from locking in place.
Cheers
Dan
Dunno if it's any help but I had no trouble on a x38 Maximus Formula...
i fitted it my own way couldnt twist the heatsink into palce no matter what i tryed so i just placed the heatsink on the bracket the way it needed to go then screwed it in....
Thanks, I've ordered some. I will have 10 spare so i'll let you all know when to head over to MM if you need any
