another reason i do not like opening up my case is because of a risk of aluminum dust from the screwholes of the case shorting something out, or some copper wire filaments from some work that was going on in the room a few days ago... was looking at the bios just now and there was a beeping sound and the screen went blank, after i powered on the computer again windows asked me if i wanted to boot up normally...
but anyway
yes, the teeth on my block are 'locked' into the tabs but all you need is a firm grip to cause the slight twist, the teeth are sliding inside their tabs... and i do not plan to even remove the side panel on my case ever again, just in case i nudge the pipes and break up the AS5 again
also when i lifted the waterblock off the cpu just now, i saw that the paste only covered half of the cpu... reapplied with a ※ pattern and gave the waterblock a good rub around before tightening the screws... now idling at 44 degrees with ambient temps at 27 degrees
but anyway
