carmatic >** but all you need is a firm grip to cause the slight twist**
IMAO > wow the majority of CPU Cooler's would move would move if you did the above!!!
At the end of the day it was your thermal paste application that let you down(high temp's) + if you are using the stck H50 fan its not the best of fan's. So you cold replace the stock fan with a Akasa Viper>push or with a Apache>pull config and check your case cooling can you improve it? Does your GPU-Card give off a lot of heat inside the case, see if you can mount a fan on the side panel blowig cold air onto it, doing any one of these suggestion's will improve yout temp's.
MY PC running p95
Core Temp's at idle after 15 min's, room temp(ambient) 19'c -
3.8GHz - H50x1 Viper fan Max RPM + 1x Apache fan: Max RPM > Viper:2014RPM + Apache:1400RPM > cores: 28'c:31'c:30'c:32'c > cores vary +/- 1'c > Noise level = near silent, l can just hear it.
4.0GHz - H50x1 Viper fan Max RPM + 1x Apache fan: Max RPM > Viper:2014RPM + Apache:1400RPM > cores: 28'c:31'c:29'c:33'c > cores vary +/- 1'c > As Above.
4.2GHz - H50x1 Viper fan Max RPM + 1x Apache fan: Max RPM > Viper:2014RPM + Apache:1400RPM > cores: 29'c:31'c:29'c:33'c > cores vary +/- 1'c > As Above.
Core temp's running Prime95(Small FFTs) for 20min's room temp(ambient) 19'c both fans at Max RPM -Viper push / Apache pull config -
3.8GHz - H50x1 Viper fan Max RPM + 1x Apache fan: Max RPM > Viper:2002RPM + Apache:1400RPM > cores: 61'c:62'c:63'c:65'c > cores vary +/- 1'c > Noise level = near silent, l can just hear it.
4.0GHz - H50x1 Viper fan Max RPM + 1x Apache fan: Max RPM > Viper:2002RPM + Apache:1400RPM > cores: 62'c:65'c:64'c:67'c > cores vary +/- 1'c > As Above.
4.2GHz due to the higher CPU Vcore, cores: 70'c:73'c:73'c:75'c, but those temp's arn't bad at all.
Running Prime95(Small FFTs) for 2hrs, room temp(ambient) has increased to 20'c from about 70min's into the run, both fans at Max RPM -
4.2GHz after 2hrs (P95 12.05 > 14.07) - H50x1 Viper fan Max RPM + 1x Apache fan: Max RPM > Viper:2002RPM + Apache:1400RPM > cores: 72'c:74'c:74'c:76'c > cores vary +/- 1'c.
Hope this help's.
