- 19 Sep 2007
Love to get one of these..
I'm tempted even though my CPU is at stock..
If I were to get one, which would be the best for my case? Antec P182 Midi Tower.
If my h100 does come with pre-applied paste is it worth cleaning it off and using some AS5 or MX 2/4 that I have somewhere or will the paste be good?
Just plumbed for an H100 - am hoping that as they're refurbished they won't have the rattling pump issue...
The H80. I asked the question a few pages back on that model. small world ehy?![]()
Ordered an H100 in preparation for a Haswell upgrade.
Would be rude not to, plenty of space in the CM690 II.![]()
Does the H80 come with the 2 fans? Just asking as the picture doesn't show fans, and as they are refurbs, PLUS a I know a lot of people change the corsair fans for other brands anyway. . . . so thought id ask before I buy.
Out of interest, where will you be mounting in the 690? At the top drawing air in?
is there a big difference between Corsair Hydro H80 and Asetek 510LC Liquid Cooling system w/ 120mm Radiator ? Also do you have to use the fans that come with it or can we put our own led light ones?
Rad is thicker on the H80 so should give better performance (I'd estimate between 3c-8c roughly, completely depends on your setup though). You can use whatever 120mm fans you want on it.
