Permabanned
- 19 Jul 2012
- Buckinghamshire
With a 90 warranty I would not buy these. I don't care how cheap they are. Thanks but no thanks.
Sounds like youve had a bad experience with your Corsair H100i ?? Im still undecided atm! But im very tempted, if they are in good condition no problems and work just as a brand new one not to mention you haved 90days if it works for that long it should work further imo cause if there is a fault or problem with it you should notice it sooner than rather later id say
would the H100 fit in an antec 300?
Not if it leaks you wont.
The only issues I've had are the LED's fail. the Hydro series are 1.000.000.000 time better then these cheap coolers
Hope this ship don't get delayed, 6 weeks is already long enough.
according to the descriptions these are the hydro series coolers aren't they ?
i have ordered the h60 for my spare pc.
These are not the hydro series coolers. The hydro coolers are more expensive.
And only £65 more!!!
you do understand the concept of factory refurbished right?
lol I sure do mate. That's why I'm avoiding them![]()
I'll have the £65 instead thanks!
You can take your 90 day and I'll take the 5 year
Sounds good to me![]()
So you're saying they go wrong that often that you need 5 years worth of warranty?
If I had something that was going wrong that often that I felt I needed a 5 year warranty I think I'd look to get something else completely.
Nah...I'm pretty happy with what I have thank you.
You all can enjoy your cheap coolers![]()
