Can you link meBigmac,I think I am going to go with bungee cords. Looks like a cheap and clean way of storing the hd's.
Here's mine.
Out with the old...
In with the new!!!
Here's all my kit!
Finished!
thinking about getting one of these is the airflow good on the front i noticed the front panel has a block and not grill does the air come in from the side of the gap? its put me off it a bit still debating to get 450d
the airflow is quite decent. gaming on air at the minute and never had a throttling issue.
whenever I bench or stress test, I just pop it open to make sure but it's not necessary
it draws air from the sides
yeah i noticed that only thing that put me off was someone had a candle inside the case and it wouldnt blow out while the front was on and when it was taken off the candle blew out only reason i find this a issue is my 280x toxic does get hot
quick question would it possible to fit a 240 rad in the front the another in the bottom? thanks
Much of a temp drop? Might try something similair as my top card gets a bit toasty too. Non ref cooled models though.Hey guys, what do you think of my ghetto cooling.
https://imageshack.com/i/f0ZSt1SBj
Had to find a way of cooling my top 780GTX, far too toasty on the M-ATX mboard.
