IMO if you get passive speakers you will have greater choice as choose own amp. Also choose stereo or a avr, and choose one with little or lots of inputs.
You won't get active speakers like back of Denon a1xva backplate for example!
I just ordered an Audiolab M-One currently on offer for £399. Looks to be a great amp. Going to be using q acoustics 2020i's with it.
Don't think it has a sub output though, if that matters to you.
That sub doesn't seem very impressive.
Agreed. £270 for an 8" sub? Can't help but feel that Audioengine overcharge for their products. A product best suited to people who like to buy these lifestyle things that have the same manufacturer and look.
BK Gemini II for £215 is a far better buy than the Audioengine S8.
Seeing the sub has an amp, where does it plug into? Does it plug in the amp for the speakers or does it plug into the pc directly??Those q speakers will be fine with bk sub. But you need a amplfier for the speakers. The sub has its own amp so you won't need a sub amp.
It depends on what you want that bk gemini will be fine in a smaller room and/or for music but if you want earth shattering bass in a large room, high SPL output, very low sub bass frequencies and low distortion fora action movies you need to spend more.
All depends on your system..if you have a regular home cinema amplfier it'll plug into the lfe output on the back of the amplfier. If you use a stereo integrated amplifier you either use speaker level, or if your amp has it stereo preouts. If you have a preamp the you use stereo preouts or the lfe pre-out. If you have a computer use the subwoofer pre-out.
And depends on what connections sub has. All have low level but some lack high level so in that circumstance you would have no way to connect it to a stereo integrated amplifier if that had no stereo preouts.
Then need to use bass management, set that up on your computer following instructions on your sub. If you are sending filtered audio to the sub bypass the subs own crossover. If sending full range use the subs crossover
What is a speaker level inputsNot sure of that shared sub output that's weird sub plus digital on same port.
But it has speaker level so make sure a sub has speaker level inputs
That shared (coax/optical/subwoofer) socket does look a little weird. Optical/subwoofer I can understand. Similar in a way to the shared 3.5mm outputs on sound cards that can also take 3.5mm mini toslink optical. Metal contacts within the socket for analogue output and a fibre optic laser and the end for mini toslink. Coax though uses metal contacts and is digital. Subwoofer connection will be analogue. Can't see how that works.
Edit: Q5 pro (which I have) is a lot more simple with a dedicated subwoofer RCA output. No headphone output though.
Speaker level inputs is when you take cables from the speaker terminals on the amp to not only the speakers, but also to the subwoofer. The Gemini II has speaker level input, which is the back circular connection labelled 'hi level input'. Not noticed until now, but they have misprinted high as hi.
It comes with a cable that plugs into that which allows wires to connect to the speaker terminals on the amp.
Whats your audio setup if you dont mind me asking. Regards
