Caporegime
- 18 Oct 2002
Are you mad?
You: Hi nVidia, so I took apart one of your cards and....
Nvidia: No.
Nvidia: No.
What else do you suggest? I feel the evidence is the picture of the chip and there's no way I could get that picture without taking the backplate off.
basically sit on the card until it fails and pretend it was never opened, especially if you didn;t actually change the pads.
Any ideas guys? It's rock solid when I touch it so I doubt I broke it. Going to check if it still runs.
Are you mad?
Nvidia: No.
Why would he be mad, probably damaged it disassembling the card?
hi nvidia, i took the card apart. I wanted to mine a bit more, and keep it cooler whilst mining.
I knew that I would invalidate the warranty, but i done it anyway and in the process i damaged it. yolo.
Can i get another one please?
nvidia: no.
damn right i say.
i would not run that even if its stable. Try get it RMAd or repaired.
There could be a fair amount of voltage running through that capacitor. Which could cause a fire and or short circuit..even though it appears stable.
Moral of the story dont open the cards,
A) unless you know what you are doing
B) expect to damage something.
Who is mad here ? LolWhy would he be mad, probably damaged it disassembling the card?
nvidia: no.
damn right i say.
What's with the hate? Did mining kill a family member?
I mine when not gaming using electricity from a green supplier.
Also the fact its rock solid and not moving is an indication I didn't damage it from simply removing the backplate (which is required for watercooling if I decide to go that route). Another indication is the card runs fine after I put the backplate back on.
I like modding things I'm pretty sure that a lot of us in this community do too. Plenty of the other members have been helpful and supportive it's a shame you were not.
My warranty is over, i fitted a water block to my 3090Fe but have to say i am pleased i did, runs nice and cool and performs as i wanted, nice and quiet to.
I was confident in removing the backplate. The fact it's running as it was prior does indicate that the card had the fault since I got it and I didn't damage it. I will be going for an rma though so thanks for the reply.
Going to request an rma tonight and see how it goes.
