"what are you smoking"
And please, pass it around![]()
The other members explained it better. Have a look at the other replies.If the card is working correct with the broken part, why is the broken part there in the first place?
Opened it.
Did you return via nvidia Web chat or the reseller?
WHAT DOES THIS WARRANTY NOT COVER?
Any problems that do not relate specifically to a manufacturing defect or hardware product failure, including, but not limited to, problems caused by abuse, misuse, negligence, act of God (such as flood), use of the Warranted Product other than in accordance with any operating manuals or other technical literature supplied with the Warranted Product, or use of the Warranted Product with software not supplied with the Warranted Product.
If it works fine just ignore it
broken part is there to sting customers if they take the cooler off. get out of warranty free card.If the card is working correct with the broken part, why is the broken part there in the first place?
I don't think that would be the case, if it was I'm sure Nvidia could be in a lot of trouble, and I'm sure you could use imaging techniques to see the PCB without taking the cooler off that would reveal this.
Clearly he was joking![]()
You're joking?
As I said, it's like a vehicle With 10 wheels, one does u can still drive.
Soldering Iron easy 2 min job. Do not do it yourself, this is not a pcb to practice On.
You're right. I have made this sound too easy. The analogy to a 10 wheels vehicle is apt - the remaining 9 wheels will keep the vehicle running, but will wear out faster and/or will respond poorly under corner-cases.
If you're competent with a soldering iron and have the right equipment, this is a 2 minute job. If not, get someone who is competent and has the gear.
As a minimum you'll need a quality fine tipped soldering iron, some solder, some liquid flux. You may need hot-air as well to warm the board depending on how powerful your soldering iron is.
Never considered that as a thing. From a cursory google it seems that this type isn't prone to cracking from high temps (it's the smaller MLCCs that do). Not saying it's not possible but just not highly reported.I hope that didn't break due to heat. With the back of the card running close to 100C due to the memory temps there is a possibility of some components cracking or getting damaged under stress. Brings into question the longevity of these cards.
@0h_no_not_again have you anything to say on this? You seemed to know your caps quite a lot from your reply.
