- 1 Dec 2015
Will DM link . PCP build . Cooler works fine with board
It's screws should have had stoppers from the start.I've managed to overtighten a Noctua NH-D15S in the past so the system wouldn't start until I loosened the screws a quarter-turn or so. Don't ask me how I managed to fumble that... I guess I was expecting the spring screws to just stop turning beyond a certain point.
Thoughts on my bar over screw fitting theroy, @EsaT?It's screws should have had stoppers from the start.
Could be simply that massive weight being the issue.
NH-U12S has become more than little overpriced since its release compared to competition, like cheaper Mugen 5.Thinking of buying the Noctua NH-U12S - i can only get the Cromax for next day delivery so £10 more for a cooler you're never going to see :/
They definitely aren't comparable.Spring pressure on IHS from base of cooler is determined by design, same as mounts without springs. All of the top tier cooler companies design their mounts to applie the right pressure. It doesn't matter if they have springs or not, mounting pressure is most important part of mount design. The shorter the spring is compressed, the higher it's rate of pressure right up to when screw bottoms out and stops turning, same as tightening mount with no spring. Both are designed to apply same amount of pressure when screws are tight. Hope that makes sense.
Agree (i'm not happy) - but looking for quick/temporary solution to test socket with a fitting i can trust for another (stock levels disappearing - can't source a Mugen from reputable place - will look again later tonight.NH-U12S has become more than little overpriced since its release compared to competition, like cheaper Mugen 5.
That "baby" is indeed fitting description for its size comapred to what coolers you can get for same money/cheaper.
Also its NF-F12 fan is one of the crappiest I've touched in 25 years of PC hobby.
At least precedessor's NF-P12 fan had OK nice sound signature and only vibrating roller motor, which I considered as bad individual/sample at the time.
Until NF-F12 had equally bad vibration level and also added restless sound profile on top of that.
Price not really an issue (within reason) - good shout re unicorn vomit version. (i'd never hear the end of it)OcUK still has two Mugen 5s in stock, in RGB version which is still lot cheaper than NH-U12S.
https://www.overclockers.co.uk/scyt...-cpu-cooler-with-pwm-fan-120mm-hs-04c-sy.html
Without RGB wires attached it wouldn't cause any "light pollution" and under that plastic cap it's standard Mugen 5.
Hadn't thought of that one - i would get a NH-U14S/NH-D15 if i trusted the socket - but need to establish a base. So, i'm going to install the stock cooler tomorrow, fit it into the case and if it works, i may chuck on the DR 4 - or pussy out and order a cooler with a more controlled method of installing.There are also others like Alpenfohn Matterhorn.
They both do the same job. Like I said, it's mount design. Some are designed to with springs, some are not. Both accomplish the same goal of mounting cooler with correct seating pressure.They definitely aren't comparable.
Springs adds lot more tolerance into keeping pressure optimal.
Without springs there's only minimal tolerance between loose mounting and very tight.
For example Scythe changed to spring loaded mounting after those cases of Skylakes bending under some coolers.
https://www.pcgamer.com/intel-skylake-cpus-are-bending-under-the-pressure-of-some-coolers/
https://www.tomshardware.com/news/skylake-cpus-damaged-by-coolers,30690.html
Possibly, but suspect i will get a generic reply that they're happy with the design of their units. Plus, the 2 units i have look fine and we all seem to be in agreement that the gap, before tightening, between bar and retention bracket seems standard - take a look ----> https://imgur.com/75LJZvlGet hold of bequiet and see about quality control of the unit you have . Will see if I can dig out that departments email if you can't find it
Thanks, @doyll.Good news! Thanks for letting us know it's working .. at least so far .. finger still crossed for you.
It is thanks, bud - but with stock cooler :/ (You can imagine my torment.)Still working ?
