I would agree that it's a lovely monitor apart from this one issue, but with the sample I've got, the backlight bleed really is a showstopper.Just taken delivery of a U2414H and it's a thing of beauty.... but the bottom left has moderate backlight bleed
That one corner is bad enough to be noticeable in scene transitions etc that cut to black, I'll try a dark movie on it later.
Shame, cause other than that it's really outstanding!
I'm not convinced by the "oh well, it's the nature of the technology, you just have to grin and bear it" argument either - of course I'm not expecting perfection, particularly at this price point, but I've used plenty of much cheaper monitors which haven't suffered from anything like the same problem. It looks to me like a design or manufacturing issue relating to the way this particular monitor is screwed together, or at least very sloppy quality control, rather than any intrinsic limitation of IPS or LED technology.
My replacement arrives on Monday; to their credit, the retailer completely took on board what I said and promised to check several samples from their stock and send me the best one.
gahhh, I really hate buying monitors...![]()
I had a Dell U2711 which died recently - it had very little backlight bleed, but it was starting to show its age in other respects, the lay-it-on-with-a-plastering-trowel AG coating being the worst offender (the P2414H is much much nicer in this regard).And what was your previous monitor, out of interest?
Oh yes, I do appreciate what you're saying, but in my experience they're *not* all the same; some are clearly better than others, not just from one model to the next but between different samples of the same model. And yes, in this case I *do* notice it in normal use - for instance, scrolling this thread to the bottom it's clearly apparent around the "Posting Rules" box at the bottom left, and to a lesser extent all the way up the left-hand side. This is in broad daylight, with the backlight at 15%.If you get to concerned about backlight bleed, it makes buying monitors a very stressful experience. Yes, I am on my 3rd Dell P2414H which still has backlight bleed on the corners but you don't even notice it in normal use so what's the point being bothered about it? And realising that every other IPS monitor is the same, there is nothing you can do about it anyway.
Just get on with it and enjoy the monitor!
Tempted to grab one of these to use as my main monitor.
How are people finding the backlight? I think it's meant to be flicker free/very high frequency.
Also didn't somebody mention they could overclock their monitor?
Yes it's completely PWM-free (i.e. flicker free) as mentioned in my review. And you can overclock it to 72Hz+ comfortably (unlike the U2414H which doesn't like going beyond 65Hz it seems).
Well, the replacement is a *lot* better - still a bit more bleed in the bottom-left than I'd ideally like, but it's minor enough for me to chuck into the "life's too short" pile, particularly at the price.I do hope your new P2414H is better! There were quite widespread backlight issues on the U2711 in general as well. You got a good sample - but there are good P2414Hs out there as well. It's annoying having to play this lottery, I agree, but it is just how things are with LCDs at the moment.
Not sure what you're referring to here - the NVidia limited range (16-235) over HDMII'm tempted by the U2414H, the only thing putting me off is an alleged issue with the monitor being recognised on Nvidia as a HD TV rather than a monitor which causes some calibration issue. Any thoughts on this? There is a hack but it means reverting to HDMI.
Not sure what you're referring to here - the NVidia limited range (16-235) over HDMIbugfeature is well documented, and it's easy enough to get round using NV_RGBFullRangeToggle or the madNvLevelsTweaker utility bundled with madVR. Or you could just pick up a DVI>HDMI adapter for a couple of quid and use a DVI output on your graphics card, bypassing the problem entirely.
PCM2 apparently ran into a similar problem using the U2414H's DisplayPort input with a GTX780, but is there any reason you particularly want to use DisplayPort rather than "reverting to HDMI?"
Or is this another problem entirely (if so a link or further details would help)?
I'd say yes based on my own experience, it grows on me every day.Spent the day trying to decide which monitor to buy but I could not find the P2414H below £170 when delivered to N.Ireland.
So the Dell UltraSharp U2414H was only a little extra. Did I chose Wisely? Want it for gaming/internet
Other than that its an impressive looking monitor. I personally cannot see any backlight bleed at all on mine unless it is hiding itself as ips glow. Pretty impressed I can only describe the quality as natural.
How does it compare to your old NEC?
My understanding is that the NEC was a class leading monitor (of its time).
