I know it's not the first monitor you've owned, but how many IPS monitors have you owned? Or closely monitored user feedback for? There's no point making out like this is just a problem isolated to the 23.8" IPS panels either - that's completely misleading. As I've said previously this is one of the better IPS-type models out there even when it comes to backlight bleed. It's difficult to believe, I know, but as some one who is very much in touch with all of the alternatives to this model which satisfy the same key criteria - I'm telling you, this is on the lower end of the 'problem spectrum'.
I can quite agree that modern IPS panel monitors in general have a higher incidence of black uniformity issues compared to other panel types. VA are generally very strong in that regard and TN panels are a bit variable but usually seem to suffer more from clouding than obtrusive areas of backlight bleed these days. If somebody comes to you saying that rich and well-represented colours are particularly important to them, they want a 23-24" model and plan to do everything from gaming to a bit of photo editing and have a ~£200 budget what do you recommend to them? Because models with IPS or IPS-type panels are clearly the strongest at matching those criteria and when you look at the current models available the P2414H is right up there at the top. The excellent luminance adjustment range, flicker-free backlight and fully adjustable stand are also big bonuses for some users.
