DiRT 4
try keeping it default and in dirt rally lower the torque alignment to 30 and turn off soft lock.
many people have t150 t300 and t500 wheels so you should fine decent settings about.most of the thrustmaster settings for dirt rally are similar.youtube has loads or even copy vajbs who live streams most days.
WRC 6 isnt close to as good.maybe it just suits how you want it.
as i posted before its all about getting your wheel right.many over complicate things.default wheel settings should be fine then adjust ingame.
Ok thanks i will give those setting a try and report back:)
Nah still not feeling it.. it just feels like the cars are weightless and the force feedback is poorly implemented.
Go back one page my T500 wheel settings are posted.
Master Gain settings %>
Overall strength of all forces-56 turn this up to get a stronger FFB.
The FFB is mediocre at best, you must have played some games with shocking FFB to label Dirt Rally's "Brilliant".
played all the car games. only ones i really rate is assetto corsa and dirt rally.now dirt 4.if people are setting their wheel up wrong doesn't matter how good it is in-game.
steam pre load is up.
Am I the only one that absolutely loved dirt rally and all the previous dirts but just don't like the look of this?
In what way?
Graphics are far better in game than on YouTube due to how YouTube compresses the Dirt 4 video upload so l'm told.
The only way you can find out is to buy it and judge it yourself, l pre-ordered my copy ages a go.
Hi thanks for this i have used your setting and they work really well apart from forces at 56 i found it to be to weak for my liking so i upped it to 90 :)
Yes it is l got this set up from someone else so l just copied the settings but edited the post to mention this.
Glad you like it.:)
In what way?
I don't even know tbh, the fact all the courses are generated seems meh and the events you work through are seemingly boring.
Early reviews arnt great but just ok, think I will wait till its a bit cheaper.
Shame as I was really looking forward to it.
I have a T300RS and i have tried varies settings for dirt rally even WRC 6 feels better.
I have ordered the game anyway i just wanted to know if they have improved the way the wheel feels if it's no better i will just use my xbox pad.
I use the T300GTE myself and did the following :
Downloaded and installed this : http://www.racedepartment.com/downloads/impact-force-feedback.6603/
And used these settings : http://www.assettocorsa.net/forum/i...topic-dirt-rally-wheel-settings-anyone.42145/ (The 10th post down)
One thing i did change was I think called "Saturation", turned mine to about 70%
See what you think.
