Dremel Dream Machine!
one more shot ... love the braids !!
Nice one, the blue and white works well together!
Just one thing, the blue light tube at the front of the rad at the top is a bit too bright in the open like that, if you put that behind the rad so that the light goes inside the case lighting up the motherboard it would look 10x better imo.
thats one awesome quality build there mate ;).
tbh, i was expecting you to say " i put everything back in , then the case collapsed" :D
now maxxxx it out :cool:
...and get ya wife to hide the dremel ;)
The psu looks well in there, Really nice build.
I worked out a lot better than I thought, thanks m8 .. despite dremeling the hole in the base, the feet of the case still obstruct the right andle PSU cable so it doesn't sit flush .. I "could" fix it .. but I'm happy with it for the time being, next time I rip it apart I'll make changes
Epic thread. And excellent build :) Makes me really want a Dremel now too :p
Hi, My name is Jay, and I'm an alco... no wait .. wrong room .. I'm a Dremel-holic !
Fantastic build, well done :)
Thanks so much
perry081064 said:
thats one awesome quality build there mate .
now maxxxx it out
LULZ ! no kidding, she's got me steam cleaning the kitchen to get rid of my mess !
To be fair I half expected it to collapse or start smoking or for there to be explosions and fireworks... So far so good, leak testing and bleeding has ensued
Overclocking and beating the living sh1t3 outta it .. begins apace ... after I get a rest :p
Reaper652 said:
Looking very good now, all the dremel work is paying off The last few pics even distracted me from watching scarface .
It's kinda like scar-face .. in box format :) thanks tho
timciren said:
looks great but time to spray that RAM !
I have investigated this .. I'll either
just spray the heatsink white
pay £100 and get it anodised in blue / white
I'll get the extended fins in Black from corsair
or
put some RAM fans over the top and hide it !
Nah just use a normal sized dremel
and get yourself one of those mmmmmmATX boards
Seriously though, nice work.
Quick question for you OCD-OC:
Which Dremel did you buy? And which attachments did you use to cut things, and what did you use to cut those perfect holes for your fill ports? Thanks ^^
dremel 300 basic tool
100 piece cutting tool (used mostly the slim cutting blades which u get about 50 of)
for the fill ports i used the drill + 20mm hole cutting attachment thingy once i had cut a pilot hole after marking up ..
if you need any more please ask..
