ArchAnGeL said:I've tried the two pencil mods and while that did solve the v droop the maximum didn't increase.
I'm not sure my soldering skills are up to attaching the resistors though.
Darg said:I was talking about these
I'm not sure if they'll make any difference if you already have your motherboard CPU voltage set high.
ArchAnGeL said:need more volts that the p5n-e can supply really. Falls over in orthos at 4.1 but can run dual superpi.
easyrider said:Nice find but he would need more than 1.6ghz for higher clocks
Sipha said:How are you insulating the motherboard Easy ?
easyrider said:Right guys I'm back,
After an in depth converstaion with messiah khan lol.![]()
Windows is on and im idling at -35c
Remember this is unit thats quieter than most so I'm pleased to at least have it up and running.
I have some pics of my insualtion install I'll post them in a bit ,I have to install a second psu to trick the phase to stay on all the time when I'm clocking.
Once I have the ultimate clock I can then setup the unit as a normal install.
Its anoying having the phase unit switch itself off then waiting for it to start again so the next step is getting a second PSU hotwired to the phase.
Thanks for all the interest BTW its keeping me going.
It took me 4 attemps to get the head seated correctly !
ArchAnGeL said:Is that the core temp or evapourator temp?
easyrider said:core temp
what are you using to measure temps in windows?
Tat?
coretemp?
speedfan?
messiah khan said:Glad you got it sorted in the end. You get the second PSU set up ok?
