men, you guys are a disgrace to masculinity, use a Machete, and finish it off with a gas trimmer.![]()
I did have a chuckle at that...
Why did you go back to the Panasonic?
In my experience they all shave about the same, what you're paying for is a fancier recharging station largely.
I've gone from a 3 to a 9 and the difference is immeasurable, the wife is getting fed up of me telling her how good it is. I'm touching my face now and it's as smooth as a babys bum but with the 3 I had to go over it with a razor.
Interesting, how long you had it?
Of course I could shave 'normally'. I've got a few wet shave razors - my favourite being the Wilkinson Sword Hydro 5.Are you saying you can't shave your skin smooth?
Even using the hot shave method?
What's your view on the cleaning station?
The same razor without is £109 so interested if you think it's worth the £40 extra?
If you're talking about the Panasonic I will probably never use it.
Punt;30490590 said:Picked up a Panasonic ES-LV65-s the other day, mainly after SexyGreyFox's gushing review of the ES-LV95-s. This is the exact same shaver but without the cleaning dock thingimmybob, so a few quid cheaper.
Now I've only used cheap electric shavers in the distant past and didn't stick with them because they were a bit crap.
I can honestly say this gives an almost close as a blade shave. I never knew that was even possible. Next time I'll try it in the shower with a bit shaving soap.
I only need to shave a couple of times a week but this being so quick and easy, I could see myself being clean shaven every day!![]()
Evangelion;30490810 said:I have a very nice Panasonic ES-ST29 imported from Japan. Best electric shaver I've ever used.
SexyGreyFox;30491403 said:I told you didn't I, I bet you didn't believe a shaver could get so close?
Punt;30491429 said:Yes you did and no I didn't. I'm very impressed indeed!![]()
SexyGreyFox;30491403 said:T'is just a toy compared to the LV95
