Did the lick your wrist test and no smell which means my breath is fresh.
It’s got some kind of clever 3D technology, I have the Oral B app installed on my iPad and have it next to me when I do a guided session but I don’t look at the iPad whilst brushing. I can still achieve 100% coverage and 0s over pressure doing it this way.how does the brush know where it is to generate these coverage reports ?
I move my head whilst brushing teeth, and wander around - who doesn't.
if the brush is using BLE and you have to have your phone where you are brushing your teeth that's an issue too.
The tooth paste dropping out of your mouth onto the sofa might be a problem.Can you use the Oral B iO range whilst seated on a corner sofa ?
usually brush sat on the end of the bed , watching tv ... dribbling isn't a problemCan you use the Oral B iO range whilst seated on a corner sofa ?
The coaching on mine has taught me how to brush with an electric brush correctly, started out not brushing all surfaces and applying too much pressure.i own a electric toothbrush with Bluetooth app connection. One sucker born every minute it seems.
Well now I've begun glancing at my iPad to check when I've achieved 100% coverage so I know when to stop, because of this my brushing time is coming down. Managed to do 100% coverage just now in 2:36.It’s got some kind of clever 3D technology, I have the Oral B app installed on my iPad and have it next to me when I do a guided session but I don’t look at the iPad whilst brushing. I can still achieve 100% coverage and 0s over pressure doing it this way.
OK - io brush location is now calculated based on AIchatGPTmodel - your brushing strategy will need to follow the norms of humanity, previous 'genius' model, you had to look at the phone.
Whats the best water flosser? or one someone can recommend as a good one? or are they just a waste of time?
I mentioned one the last time I saw the hygienist and she said they were a waste of time.
Probably to make sure you keep seeing her to get paid.
