They all state wireless/WiFi --- and there is enough of them showing up with positive feedback being left? I did ask someone FB Marketplace what the crack was, given it is WiFi it'd likely report serial number etc... They then ignored me...These ones aren’t smart are they so can’t be officially installed.
I don't know what you mean by smart then?That’s not smart. Just means you can connect with an app
But they are solo3. Prob fell off a lorry
Solo3 can do that - if you mean via tariffs that enable it. It is one of the two approved ones for Octopus Go.As CEO of the Charger install board.... Smart means the grid can manage the turn on times to stagger the demand.
Something I should have made clearer at the start I guess... The dedicated control unit with thermal managment is in the charger you PLUG IN to the commando socket.Please don't compare a high power commando to a 3 pin with a dedicated control unit and thermal management.
Most granny cables are limited so don't pull the full current from the line, but if it's an old house than pre-dates many of the modern regs and hasn't been rewired I'd certainly be concerned with long term high current drain, our old condenser drier used to pull ~3kw and the heat I could feel build up around the plug was a concern after only a couple of hours, I was never that happy, I certainly wouldn't want to go to sleep/or leave unattended with something like a car pulling high current for hours through decades old wiring without having it checked to ensure it's good for it but perhaps I'm too cautious.
Grand scheme of things a properly fitted EV point at £500-1k is peanuts really and so much more convenient than a house fire.
Are there any reputable figures around that compare public chargers to EVs on the road over the last few years?
Not sure but there were ~630K BEV's on the roads by the end of 2022, vs ~97k at the end of 2019.
Yeah my granny cable on the PHEV only pulls 10a. I was getting quoted £1500 for my install, i think as PHEVS and BEVS start falling into the used markets, you will see a lot more ropey installs.
I must admit my Podpoint was a used tethered charger, its served me well for the last 3 years, I used a common and garden sparky to do the install, my cost including a new Hagar RCBO CU & outdoor socket upgrade was 750.
We may see a lot of car dealers rolling in a charge point install into the finance deal that'll inevitably be used to buy the car.I think it'll be interesting going forward as you say now the market is starting to be flooded with used EV's coming off lease.
If someone was to pick up a used Ioniq or e UP! or whatever for say 10 or 12k in 6 months time, do you think people will be happy to spend 10% of the purchase price of the car on a charger, i bet a lot of people wont.
It's a different story to the guy getting a 50k car on salary sacrifice, what's a grand here and there to someone in that position? but the regular person who's used to spending 10k on a used car will be counting the pennies much morel, i'd expect to see lots of 'hacks' and threads on reddit on how to do it on the cheap.
But in 2019 the devices were barely used and losing money hand over fist![]()
EV charging statistics 2025 - Zapmap
Tracking the growth in charge points across the UKwww.zap-map.com
ZapMap has a couple of statistics here, but I suppose it's difficult to make a ratio because which stat do you base it on? Devices, connectors?
If we just go on devices, they have about 17k devices at the end of 2019, or about 5.7 cars per device, then end of 2022 is about 37k devices, or about 17 cars per device. This is definitely not the direction we need that ratio heading![]()
True. If you look at the ZapMap stats, looking at only Rapid (25-99kW) and Ultra-Rapid (100kW+) makes things a lot worse - 2019 is 33.5 cars per device, 2022 is 91.3 cars per device. This is not even taking into account location, nor the fact of how many of those devices are actually in service (or how many vehicles they can charge).The type of chargers and their location also matters.
