Awesome work evga, grabbed a Evga 970 because of your great support.
Hi Neil, Yes, this is no prob, as long as the Chipset and the ammount of RAM on the card is the same it will work. SLI just works best when both cards are sinked so the advantage of the classi will be gone if the other card is not clocking as well
My 980 SC is clocked at 1563/7856
So pretty high
Oh and thanks!!
Whuuaat 1563 is an awsome OC on a 980!!! Then it should be no problem
Nice OC
Great news. Seeing this thread is one of the reason why my third TX (well second as my 3rd is now gone) which arrived moments ago is an EVGA SC version
Already putting it through its paces, but paired with my 2nd SC version both seem a lot happier in SLI. Getting much higher stable clocks now as this one seems to be a good chip. And the Green LED is brighter
Separately also I thought I would try out the ACX 2.0 cooler, but it came with a random GPU's retention plate that does not fit on the TX
Hi, accessories are shipped, have updated your email with tracking of the shipment.
Hi, where did you get the ACX cooler from? Usually if the cooler is a Titan one the plate should also fit? Maybe its a block for an older Titan black or the originally one?
This is the wrong one. Was the box originally sealed and shring wrapped? Are the marks at the thermal pads from your installation or had the thermal pads looked like this out of the box? Did you return this one for a refund?
