ok up'd the clock to something reasonable 3.745ghz (1.45v load vcore) and let the fans go to see what sort of temps I got.. again just a quick blast on prime (I know these settings are 8hours+ primestable same settings I used for the entry on the quadcore database).. thought it would also provide a good comparision between new and old..
So old setup at 21c ambient was achieving temps of: 63/63/57/57 (Pre Ducting)
current setup at 23c ambient is getting: 52/52/50/50... also this is on a new AS5 mounting last night so probably a good few degree's to come off those once its bedded in a bit
Am certain these temps will hold I know I am moving enough air in the case not to case overheating due to increase in ambient temps... Also got to sort the RPM reading in speedfan.. fiddle with the divisors should sort that
