Is it possible to do the career with the real drivers and not as an avatar?
You can do a championship as a real driver, but not play as any in career mode I'm afraid.
It’s one the things that bugs me the most about the game 1st Hamilton, 2nd a red bull..... I was excited when I found the list of names to be disappointed that mark wasn’t on the list. Mark is on all lists!!
Went for the professorbe the rainmaster or iceman
It is a shame no vr, apparently there is a work around which works ok but I’ve not had time to try it.It’s a shame it’s not vr, does it work ok with triple screens? Thinking of getting this to have a go, haven’t properly played an F1 game since 2012...
What is the VR workaround you mentioned?It is a shame no vr, apparently there is a work around which works ok but I’ve not had time to try it.
I play on triple screens and it works perfectly in game play, just menu sometimes is a bit broken. HUD is adjustable so you can put it all on Center screen.
I’ve not tried changing FOV because it’s ok for me, I’m pretty sure that you can change it though.Can you change your FOV with triples? Also do your side monitors look warped? Thinking of picking this up but I play racing games with triples.
Triple monitor setup guys, what graphics cards you guys using and at what resolution?
Cheers mate.I don’t know how good it is as I’ve not tried it yet
http://forums.codemasters.com/discussion/137584/someone-did-get-it-to-work-in-vr
Ah really?1070 with 3 1080p monitors,I can’t remember whatever that works out at.
Everything on max run very well
Never taken note of frame rate but will have a look and report back when I canAh really?
I have 1920 x 1200 monitors, and a 1070, but its not silky smoothy....
Some people can put in ridiculously good times with a pad (faster than some peoples wheel times) it depends on how competent you are with the pad.Is this game playable with a controller or is a wheel required? I don't really have the room for a wheel at the moment.
