Permabanned
- 2 Apr 2007
I got a playseat, more convenient than wsp and lighter
No way is a play seat lighter! Can it be folded down and put away?I got a playseat, more convenient than wsp and lighter
Getting my new wheel today XD ! Fanatec CSL Elite with a Formula Rim, can't wait!
I have both and I find it a lot easier.No way is a play seat lighter! Can it be folded down and put away?
Nice one! What pedals did you go for? I'd be interested to hear your first impressions as I'm thinking of upgrading from my G29 to the CSL.
I love a bit of F1.
I actually upgraded my pedals a few months ago to the CSL Elites w/ Load cell, and they are really a step up from my old Thrustmaster T3PA Pros. On the T3PAs, I had a bushing behind the brake pedal on those to stiffen it up, but never had the consistency I have with the Fanatecs, even the throttle pedal is more consistent! I'm pretty pleased with them, now I'm a few days away from completing the Fanatec setup.
It's the CSL Elites with load cell I'm looking at too so it is good to hear they are really good pedals.Which config/bundle is it your are looking at bud?ThanksIt's the CSL Elites with load cell I'm looking at too so it is good to hear they are really good pedals.
Ah. Didn't you want to go with all load cell pedals?
Is there a all load cell bundle?
Good insights, thanks bud, may I ask if you could link to the exact gear you ordered?
I’ve been toying with this exact setup. Only problem is that it has to be desk mounted. I don’t have the space for anything else. Do you think it would be ok or am I wasting my money? Have a g27 currently.Sure, I ordered the CSL Elite Wheel Base + (because it's PS4 licensed, even though I probably won't make use of that) and the ClubSport Steering Wheel Formula V2 EU (I wanted the 2019 version but out of stock). And I already have the ClubSport Elite Pedals LC from earlier.
I didn't go with the starter pack as I already had the pedals.
Thanks for the reply,This isn't from first hand experience but I've done quite a bit of reading about Fanatec wheels recently. The wheel clamp is supposedly a good clamp, similar to the Thrustmaster clamps. The FFB is stronger with the Fanatec wheels than Logitech, from memory the G29 (which I'd assume is similar strength to the G27) has a torque of 2.2 Nm and the CSL Elite is ~6 Nm. So you have to consider if your desk is strong enough but I'd imagine any full size desk would be. The pedals are a slightly different issue, the normal 2 pedals are fine apparently but the addition of the load cell means you need something to stop the pedals sliding when you're applying heavy pressure on the brake. Though I'd imagine as most desks are against a wall that the wall will act as a pretty good stop to the pedals sliding away![]()
