Cyber-Mav said:gonna reinstall farcry this weekend, then see if hdr works on this ati card, if not then something is borked with the cards drivers since this same install of farcry gave me hdr on my 6800nu, 7600gt and 7900gs.
Nutbusta said:Well since I last posted on this thread Far Cry now won't run
It appears to work fine until the level finishes loading and then my machine just reboots.
The only thing I have changed since then is a slightly higher overclock (which I've tried backing off) and setup Gigabyte "I-Cool" to slow the CPU fan and I've tried turning this off as well?
and I was looking forward to playing through this again![]()
JAKUS said:Check out the Render Mode in GFX settings..Put it to default, Mine also mysteriously changed![]()
turn of windows auto restart on crash (Start up recovery options in My computer Properties) will not fix the problem but may give a Luvly Blue screen code..![]()
Bizarre said:I use \r_hdrrendering 7 and \r_fsaa 4 which gives me HDR+AA goodness. For those who can't get it to work are you sure your typing the commands correctly, as the above commands should work perfect with any x1 series card and farcry patched to 1.4 (beta or final).
no_1_dave said:I use setting 7
Oh & AA with HDR isnt supported in farcry even on ATI. Its buggy...
), and towards the end of the game I got funny coloured horizontal dashed lines across the cut scene videos... no problems during normal gameplay though. Just hope it isn't a sign of my GT beginning to b0rk
JAKUS said:OK,
do You find much difference going higher or lower number ? PQ or does it just give you better frame rate ?
Sumanji said:Sorry, off topic, but is v1.32 the latest 64-bit patch?
Quixote said:Hope you don't mind me adding a question to this thread. Has anyone on an ATI card got VSync working on this game ?
I upgraded from a 6600GT to X1800XT & although I can turn everything up stupidly high Vsync simply doesn't work when enabled.
I can't play games without Vsync. Any of them. At all. I'd rather have low detail.
Anyway, if anyone can help, cheers.
