- 20 Jun 2023
- uk
I've had ours on most of the day. Pallet from work mainly.
Thanks I did watch their videos a bit before we got it, very informative channel and we ended up getting the Woodpecker because of their review.Recommend tortises videos on you tube.
In other news, I heard a strange noise and thought some kids had a quad bike out the front so went for a wander earlier on.
Turns out it wasnt it was a guy from the parish council who was moving some of the logs I had my eye on.
He said he was moving some for the school who wanted some for a wildlife garden but we are fine to take any logs we want!
So tomorrow is testing day to see what I can move and probabaly more limiting what I can get home before erindoors throws a wobbly!
Also, have decided to light the fire so running in now. I am pretty sure the cement will be set.
All the guides I have seen say leave it a week, its been 10 days.
Not exactly a nut but I did get the side off - normally the blade is loose and you take chain off but this blade doesn't do that so can't get chain off.Never had one but Hasn't it just got a nut on the side make sure the brake is off. Undo and remove cover
Have a look on you tube.
Any tips of getting the corners of my stove glass clean, I don't want to use anything abrasive incase I scratch it?
(sure you can get them cheaper too!).Yeah it goes stay pretty clean but I don't want the corners to be too black long term.A hot / rolling flame should "self clean" the glass
Failing that,.spit, ash and newspaper works well or,.if you want something a little more off the shelf, these work well(sure you can get them cheaper too!).
You shouldn’t be able to scratch glass.Any tips of getting the corners of my stove glass clean, I don't want to use anything abrasive incase I scratch it?
