I always check the ash even the next day by moving the remaining ash around and check for warmth.
Not sure why you would want to deal with hot ash? Also maybe i am wrong but the ash can be put into the soil or am i wrong? It doesnt have to go into general waste
Speaking of which. Anyone got any recommends for an ash vacuum?I use an ash vacuum cleaner, less dust, holds enough for several cleans and can handle hot ash.
This is why it's better to have a smaller log burner and run it hot, then have a massive one and run it cool.Thanks I did watch their videos a bit before we got it, very informative channel and we ended up getting the Woodpecker because of their review.
The problem ended up being fresh wood, I've had a different load delivered from somewhere else that is mostly ash with a bit of alder, and all seasoned since March 2023. No problems reaching temperature now, I suspect what I got the first time was still partly green. There were bits that I'd split for kindling that foamed and sizzled on lighting which I don't think is right. So the fresh batch went all the way to the back of the log store to season and completely surrounded by the ash which was about 1/3 of the price too.
Question I have now is whether a bit of primary air to keep flue temperature up is normal? If I totally close the primary, the flue thermometer drops into the creosote region and doesn't really recover even if I open the secondary air all the way. We just end up getting cooked approaching 25C+ but the flue is apparently still forming creosote. But a touch of primary air still open gets the temperature back up and we can still regulate the heat radiated into the room downward with the secondary. Is that something that sounds OK? What's more important - primary air totally closed or the (potentially unreliable) flue thermometer reading?
When I was younger I never thought there would be such a thing as wood envy
