First Water-Cooling Experience
14 Oct 2011
Kent
I have never touched any sort of water cooling and would like to know if these will all work together. Underneath is the specification of the computer I want to buy. Will the case be ok. And underneath that is the water-cooling gear. Are these water-cooling parts compatible.
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x MSI HD 6850 OC 1024MB GDDR5 PCI-Express Graphics Card £83.99
1 x MSI Z77A-G43 Intel Z77 (Socket 1155) DDR3 Motherboard £77.38
1 x Corsair Builder Series CX 600W V2 '80 Plus' Power Supply (CMPSU-600CXUKV2) £52.99
1 x BitFenix Shinobi USB3.0 Gaming Case - White/Blue £49.99
1 x GeIL Dragon 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (GD38GB1600C11DC) £37.99
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £17.99
1 x BitFenix Optical Drive Bay Stealth Cover - White £3.98
Total : £517.80 (includes shipping : £11.25).
Now for the water cooling
YOUR BASKET
1 x EK Supreme LTX CPU Waterblock - Nickel Acetal £32.99
1 x EK CoolStream Radiator XT 120 (120.1) £26.99
1 x EK Reservoir Combo DCP 2.2 £19.99
1 x EK-DDC X-TOP Rev.2 Acetal Pump Top £15.98
Total : £106.45 (includes shipping : £8.75).
What else would I need?
What coolent is best?
What dye?
Which fittings?
Also for the GPU?
EDIT: Was meant to put a 670.
Also which case would be good?
Why do you have a pump top? That reservoir does not come with a pump.
You need a pump + tubing. (G1/4) compression fittings to match the size of tubing.
Yep those kits have everything, its pretty much the same as the items you were listing above but cpu block is slightly different. I don't know about cooling the 670 but if you do that you will need to buy extra tubing + fittings.
I'm not sure about how good the pump is that comes with the kit though, you could put together a better loop yourself depending on your budget.
I think that I will spend £100-£150??? Is that ok, or should I just get a phanteks air cooler?
Its pointless watercooling with a single 120mm rad.
The case is also not geared for watercooling.
Unless you cut out all the front but then you can't mount any HDD's.
Ok thanks, which case do you recommend?? Also what type of radiator??? 240 360 480 etc???
As a rule of thumb you want 120mm for each component + another 120mm.
So for just a CPU 240mm.
But i would get a D14 as its cheaper and cools better than a single 120mm rad.
I'm not really sure about the case but you could get a shinobi XL as it takes a 360mm.
But i would not go with a watercooling kit unless you have quite abit of money.
Ok thanks for your help guys. I will probably go for water-cooling in the future. For now I will get a good air cooler. Also if a custom loop has all of these things then how does a closed loop have no res or anything??
Thanks
Bakht
Wow, how much was that water cooling kit???
Also I have seen oil cooling? I don't want to do it but find it interesting
Is it closed loop??? With that good temperatures? I might as well try to get that when I get around to buy :)
Those closed loops have the res in the rad and the pump in the block. I suggest an antec 620 over the air cooler. I changed from a high end aircooler to a swiftech h20-120 compact with my 775 system and it was muccch better, and cooler looking ;)
http://imageshack.us/photo/my-images/651/19892988.png/
Try getting that temperature on air :P
It says your CPU is at only 7*c.
Which is impossible unless you use DICE etc.
Or live in a ice cube.
My brothers computer is ice cold. 3 degrees c stock cooler amd llano a6?
On all the temp programmes and even bios it says that?
AMD chips are notorious for giving lower temperatures than reality.
Do you think that is a design fault? Or will it be fixed in a driver update. Because it might be running at 60 degrees c at idle, and we don't know about it?
