First Water-Cooling Experience
maybe £50-150??? Depends on the benefits.
It will take a long time to save up, my parents will save £100 per month. Also the stuff I am selling. So by my birthday (november)
Xigmatek Elysium :D
If you can stomach it's acquired taste looks
Really? I really like the look, It's a bit big. But it fit's under the desk. The desk is 700mm high
600 mm deep
need to move it forward.
Thanks
Bakht
YOUR BASKET
1 x OcUK Tech Lab H2O HD 7950 3072MB GDDR5 Nickel Plexi & Backplate (R7950 Twin Frozr 3GD5/OC) - AMD 3 for FREE Promotion £399.95
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x Xigmatek Elysium Full Tower Case - Black/Silver £129.98
1 x MSI Z77A-G43 Intel Z77 (Socket 1155) DDR3 Motherboard £77.38
1 x Corsair Vengeance Blue Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9B) £43.99
Total : £846.29 (includes shipping : £12.50).
+ water cooling gear
+PSU
what water cooling do I need now???
The GPU is a place holder
600 mm deep
Thanks
Bakht
YOUR BASKET
+PSU
You need all the gear in my last post with a basket, minus the GPU block
EDIT:
Not going for the windowed version?
you said your on a budget so the last thing you want to be buying is a 300 pound+ watercooling loop! :)
I'd have said te same, but to me he doesn't seem to be skimping on other components in order to get watercooling, seems more like an investment :D
Bhakt: a window is good for seeing components; that's what it's there for! It's certainly better than metal...
lol, things have changed the past years (minutes)
I was planning on bankrupting my parents a year ago with a 990x
but have decided not too. It will take some time for the money. I have learnt quite a bit about watercooling from here :)
Thanks
also will water cooling void CPU warenty? I know its a dumb question
also when I get it should I install stock cooler to test if everything is working?
edit - and definitely not a 400 pound 7950!
gonna be a 670, but when techlabs version is released, I don't want to break a £300 thing :)
YOUR BASKET
1 x EK-KIT H3O 240 HFX High Performance Watercooling Kit £189.98
1 x Xigmatek Elysium Full Tower Windowed Case - Black/Silver £139.99
1 x OcUK E2250SWDA 22" Widescreen LED Monitor - Black £99.95
1 x Corsair Enthusiast Series TX750M High Performance 750W '80 Plus Bronze' Modular Power Supply (CP-9020003-UK) £86.99
1 x XSPC EX120 120mm Radiator - Black £29.99
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £17.99
1 x Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin £13.99
4 x EK PSC Compression Fitting 10mm 3/8" - G1/4 - Nickel £2.75 (£11.00)
Total : £1,317.82 (includes shipping : £22.20).
Also what about the distilled water??
how often will I need to add more dye/ coolent/ water?
Will I need to wash the Rad with water???
also is this a good guide
Looks good to me, linus is great with guides
http://forums.overclockers.co.uk/showthread.php?t=18290835
also
http://www.overclockers.co.uk/showproduct.php?prodid=WC-063-XS&groupid=962&catid=2133&subcat=2134
could I use this instead of the one in the package?? it looks better and would be more convenient?
Yh, post in the CS section, i'm sure something can be worked out :)
