- 10 Jan 2012
Yep those kits have everything, its pretty much the same as the items you were listing above but cpu block is slightly different. I don't know about cooling the 670 but if you do that you will need to buy extra tubing + fittings.
I'm not sure about how good the pump is that comes with the kit though, you could put together a better loop yourself depending on your budget.
They're still decent and would be a good upgrade but you'd want something newer tbh. Whats your budget?
