First Water-Cooling Experience
so would that be ok for the Switch 810???
Also how often would I need to refill? is is difficult to build?
If it leaks will I be owned and not be able to RMA???
1so would that be ok for the Switch 810???
2Also how often would I need to refill? is is difficult to build?
3If it leaks will I be owned and not be able to RMA???
1) The basket i specced you won't be appropriate, try this one: note: this presumes you're going for a tech labs card
YOUR BASKET
1 x OcUK Tech Lab - V12 Watercooling Kit 360 £279.98
1 x Mayhems Pastel - Blueberry Blue Coolant 1L £14.99
Total : £306.37 (includes shipping : £9.50).
Everything you need with an epic pump of win. Get the blocks changed to whatever you want, fluid any colour (keep it pastel)
2) Pastel coolant lasts around 3 years
3) You will be owned, yes, no manufacturer accepts RMA's for liquid damage.
However, presuming you notice fast enough and nothing short circuits, then just leaving it to dry for a day or two should see it live again.
Would gigabyte be like, sure no problem, if I tell them it stopped working randomly?
No guarantees. However, Gigabyte have been among the nicer brands. There was a case a few years ago of someone wrecking their mobo with a watercooling leak and Gigabyte very kindly replaced it for him.
YOUR BASKET
1 x Gigabyte GeForce GTX 670 Windforce 3X 2048MB GDDR5 PCI-Express Graphics Card £341.99
1 x EK-FC680 GTX Full Cover Waterblock - Nickel Plexi **EN Nickel Plating** £79.99
1 x EK-FC680 GTX Backplate - Black £19.99
Total : £748.94 (includes shipping : £10.00).
For this you'll be voiding your warranty and you will need to put the block on yourself.
However, the original cooler is only held on with 4 screws. If you're careful enough, Gigabyte should never know the cooler was taken off... no guarantees at all
yep i am deffo getting techlabs
YOUR BASKET
1 x OcUK Tech Lab H2O HD 7950 3072MB GDDR5 Nickel Plexi & Backplate (R7950 Twin Frozr 3GD5/OC) - AMD 3 for FREE Promotion £399.95
- 1 x Mayhems Pastel - Blueberry Blue Coolant 1L £14.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x NZXT Switch 810 Big Tower Case - White £149.99
1 x XFX 850W XXX Edition Modular '80 Plus Silver' Power Supply £109.99
1 x Gigabyte Z77X-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £104.99
1 x Corsair Vengeance Blue Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9B) £43.99
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £17.99
Total : £1,319.56 (includes shipping : £14.75).
getting expensiver and expensiver :/
but as long as it is good for a few years and will be all compatible and be quality compnents
if I buy techlabs, will I be able to test without hooking up the water cooling and rad? or will it be ready tested?
even if the cooler/ card gets damaged?
Cooler, they'll charge you for a new one, card... that'll cost you... a lot. Depends on damage.
Honestly, if you're very careful and use common sense you will NOT damage the card :)
It should be tested already
Looking at linustechtips he has a guide for full plating? I like nickel acetel as it is black, but is there any benefits in nickel plexi?
So copper is not recomended, I will get Nickel Plexi
no, no, it's all about looks.
If you think Copper acetal looks the best, go for it!
Copper and nickel perform similarly. ONLY difference is looks, i was merely expressing my own opinion :p
also is the vga block come with the thermal adhesive
EDIT: Ok, I will get nickel anyway as on linus water guide it said that it becomes darker over time
