Folding@Home News - Attention Single-Machine Crunchers
Can you add SB to the list :)
It's a friends PC I managed to gain control of :D (AMD 3000+ @stock 24/7)
I didn't manage to persuade him to let me put 2 instances on his 3.5 ghz HT P4 :( so theres only 1 machine on SB atm unless I manage to persuade him, in which case I'll let you know :)
SB doesn't seem to be producing at the moment - have you only just added it?
linkage
Stelly I'll happily add you but I can't seem to find you yet - I have found a Stelly with no team number but that shows no work returned since last year so is probably just coincidence
If you have only just joined then you won't appear in the team stats until your first Work Unit has been returned and credited.
I can still add you to the list for next week if the name is definately correct
Hmm it should be producing, though I didn't have much time to leave folding running before I had to have it finished so something may have gone wrong. I'll be over there friday so I may be able to sort it out then.
Probably wont have any results this week lest it gets a 56 pointer or something. I may spend some time and see if I can get it overclocked and stable so if you could add it in for next week we should be seeing some results :)
Stanfords Stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=SB&teamnum=10
Date of last WU: 29.04.2006 03:08:18
linkage
Hi there,
I will start over again and call myself StellyOCUK... is that alright?? I will set it all up tonight ;)
Stelly
Thanks Rich I will make sure that they'll be some results.
I'm just interested really to see what it can produce, and the single machine leauge gives you a good idea of where you stand against everyone else :)
Stelly said:
Hi there,
Stelly
there's no need to change the name - just check your team number is 10 and it'll keep the results seperate from the other Stelly
I'm assuming it's just that you haven't finished a WU yet so you're not showing up on the stats - nothing to worry about in that case :)
welcome to the team :cool:
Addition request
Hi Guys - Please add me to the one machine list. I haven't had a 600 pointer in weeks & too many 56 wu. Glad to be part of the team :)
welcome to the forums :)
I've added you to the list and also added you to the news for last week - congrats on your 15K tiffy too :cool:
Um, what if we're crunching with really low specs? I've got my P3 crunching and its hasnt completed a WU after about 3 days.. Also whenever this PC is on, its crunching.. But theyre both not very powerful? Otherwise i'll be stuck at the bottom of the multi system list with 2 machines equivalent to one :(
well personally I don't see that it should be a problem although it is going totally against the "single cruncher" rule - if anyone feels strongly about it then I'll have to stick with that
does this mean you didn't have any luck borging your brother's PC? :(
or am I getting confused now? :p
I'll add you for now (same name as here?) and see if anyone complains
Nah my brother wouldnt let me in the end :p But my username is benjo1989.
