Was this moved from GD?? Can we leave the spam threads there plskthx.
You should use the RTM feature or "Back" button for threads you do not like.
[TW]Fox;12884616 said:Loads of people on the BMW sites are fitting HID fogs. I mean.. what?
I've got beef with exceptionally powerful high level brake lights.
I'll have to admit, I resorted to using my fog lights tonight, in non-foggy conditions.In my defence, one of my dipped beam stopped working as I was leaving from work and, being the GENIUS i am, i had left the spare bulb set at home. Clever eh!?!
Front fogs lights do not dazzle.
Whether they do dazzle or not please tell me, if it isn't foggy, what is the ******* point?
In my S2000 this never affects me, nor has it affected me when i've driven other low cars (VX220 as another good example)
they are handy when driving on unlit roads at night![]()
[TW]Fox;12882069 said:Even better are the tards who think fogs give them better visibility on country lanes even though you get an extra 2 metres of light and at 60mph anything additional they allow you to see you will crash into anyway..
On my Fiesta, when you turn on full beam, the dipped bulbs go out, this leaves a pool of darkness immediately in front of the car and when the roads very up and down, that makes it slightly unnerving at times, so I use my fogs in that instance, as soon as I hit the main road I turn them off however.
i don't do it myself, but i don't actually see the problem with it. It doesn't blind anyone, it doesn't affect you,
They produce omni directional light whereas your dipped beams produce a focused beam. I strongly suspect any gain in lighting you get from the fogs is very very small or a placebo.
It is good however that you turn them off and presumably treat them the same as main beam. At least you care about other road users
PS: I bet if you google around you'll find a wiring mod to fix that bug in your Fiesta's lighting system. Many cars from the 90's were like that for some reason. Can often be fixed by splicing two wires together in the dash somewhere...
