Does 65 make much difference to fuel consumption over 70? I assumed you would have to drop the speed right down to 50 ish.Judging by my journeys last weekend that hasn’t happened yet. I was doing 65 on the cruise control and the only things I was passing were the trucks and the occasional coach. Pretty much everyone else was doing 70 or more.
google tells me French have 5% margin, personally only had a ticket there.No they shouldn’t. Good luck getting anything to land unless all cameras are calibrated and checked out every week!
EVs arn't a 1990s laptop. Go on, provide the proof that EVs are provided 50-60% of the stating range, otherwise we'll know it's typical Nasher dump and run nonsense
For me, the argument on range for an EV is similar to the battery life of a phone.
I don’t “need” a phone which can last 2 days, as I could charge it multiple times a day. But I find it inconvenient to do so.
The same with an EV. I could stick it on charge at time, then charge when I go to the shops, charge back at home etc, but the constant charging is more of a faff compared to just sticking 50L of fuel in once in a while.
But that's your specific use case. What do you do when you go camping for 3 days with nowhere to charge your phone and have no power bank? If like robj20 you frequently take long journeys into the middle of nowhere then having a car which will only get you there, and not back is useless.
I was travelling on the M1 South last Tuesday night and there was an enforced 60mph speed restriction in place with the electronic signs labelled : 'Speed restriction to reduce pollution'. I was like - But i'm driving an EV !!Judging by my journeys last weekend that hasn’t happened yet. I was doing 65 on the cruise control and the only things I was passing were the trucks and the occasional coach. Pretty much everyone else was doing 70 or more.
whenever I see a CLA mercedes, I'm envious of the aerodynamics it provides for higher speed economy (even if the fwd and shooting break space is not so great)Obviously my car being an 4wd brick won't be helping matters!
