GeForce GTX 590 Key Features Revealed
Haha, there's always one person that shows up from nowhere though, who claim to know a guy on the inside who has leaked them info :D
Yeah I know a guy too, my mums, brothers, dads workmates, sons, cousins, nephews, great grandads ex-navy buddies, daughters, boyfriends 2nd cousin twice removed, aunties, associate has a friend who works at Nvidia, he says it sucks.
How can you guys be so sure of what setups will beat the GTX590 etc etc? We'll only truly know once the card has been released no?
There's a range in which performance falls within. So it's relatively easy to roughly guess the performance of a dual GPU card based on the supposed specs, such as GPUs used and their clockspeeds.
Posted?
I've not seen that before. It make sme question if it's dual GPU though, it looks way too small be a dual GF110 card.
Looks legit, and yes it's the 590 with 2x580 cores on one PCB. You just know it's going to cost a bomb when it comes with a gaming mouse and flash retail packaging.
http://semiaccurate.com/2011/03/22/nvidia-gtx590-cant-beat-a-hd6990/
Some interesting points if they are true. Charlie seems to think the leaked nvidia benchmarks are mainly done at low resolution with some being as low as 1280*720 with no AA/AF. He thinks nvidia have done this to make the gtx590 look better as when the resolution goes up the amd card is stronger. He also states in the leaked slides the 6990 wins 5 benchmarks out of 11 which is not a good sign as nv wouldn't want to post benchmarks with an amd card winning.
He says none of the 11 benchmarks went above 1920x1200 which sounds like nvidia can't match amd at all or much at high resolution.
He is ranting a little as usual but if any of this is true i think at best nv are only going to manage a draw. He does say overclocking could be good though.
Meh, its all weird, there will be someone who wins at stock, and I'd be surprised if that wasn't AMD assuming both cards are aimed at 375W for "stock", and a card that wins at max clocks.
The 590gtx should win at max clocks, but that also assumes that it can pull, and cool, enough to blow past the 6990 as 580gtx sli would. THe problem being, that will be two VERY high power gpu's on one card, probably better cooling than AMD's so I wouldn't be surprised if it was cooling and probably quieter at the same power levels, but watt for watt AMD has the advantage, can the card actually draw enough juice to hit the clock speeds it needs, we'll see I guess.
The other little issue is benchmarking the 6990, too many people just hit the oc bios saw high temps in furmark and that was it, the problem being 6990 max clocks and performance in games will be significantly higher than max clocks in furmark, the OC bios gives some silly "powertune" setting but the clock speeds aren't using that power up at all, only in Furmark.
What we'll need is a reviewer with half a brain(are there any left?) who will actually find the stable maximum overclocks on both cards and see who wins.
Anyone that buys either of these cards(or a 5970) and runs at stock speeds needs to be slapped frankly, stock speeds = daft pci-e spec limits, nothing more or less, overclocked = where a £450-700 card should be used.
EDIT:- Seriously, why on earth have AMD made a card with plenty of space around the fan in the middle, yet, made the fan much smaller than the width of the card. Nvidia have a much larger hole in the shroud and have fitted a much bigger fan, it seems utterly utterly retarded to not have sourced a bigger radial fan if they absolutely had to go that way, as I'm sure a bigger radial fan could provide less noise for any given airflow, but radial fans are just rubbish, always.
