- 14 Oct 2007
- Manchester
to get 5.9 for your memory you need to run it at a 1:1 ratio with you're FSB.
eg. FSB 400mhz, you would need the memory at 800mhz pc6400.
So does that mean that even if you had 800Mhz memory running at 840Mhz because of an overclock you did, does that mean you'd still score less than 5.9 in Vista even though you've actually got it running faster than the FSB (and stock)?
(In my case, 350Mhz FSB, memory running at 840Mhz effectively)
Just curious
