Man of Honour
Indeed - flushes the muscles of the crystalised lactic acid molecules currently sat in the muscle fibres.
Rather than the diet, or the technique, or the schedule what i have trouble with is motivation. Anyone want to write a section of the guide on how not to be a lazy ****?
I am wondering if anyone can point me in the direction of a good workout using just bodyweight as I do not have (nor can afford ATM) any weights. I am not looking to get huge but just to increase my strength and size a bit more.
A few searches found this - http://www.elitefts.com/documents/30days.htm
Not sure if its any good or if someone can point me in another direction. I understand I will need to shell out a few quid for a pull up bar which is fine but I cannot spend loads on any weights hence my reason for going the bodyweight direction.
Any help appreciated.
Why have you posted here?
What sort of weights? Ones that are challenging for the rep range you're exercising with. E.g. with a good beginner program like Stronglifts 5x5 you start off with an empty barbell (7ft one is about 20kg), then every workout add 2.5kg until you hit a wall after so many weeks, if I recall correctly. The idea with getting bigger/stronger is that you don't rest on your laurels and always push yourself, and if you're completing all your reps easily then you're not lifting enough.
Don't worry about people at the gym, if anything you should ask someone who knows what he's doing to help you check your form, especially for things like deadlifts.
HIIT is draining, depending on the protocol you're using anyway, and rest days should be rest days (grow/recover). Do some short but intense cardio in the morning for 15mins or something, your weights stuff in the afternoon. I'm not a fan of wasting 30-60mins doing moderate cardio. It's boring and while most people do it for the calorie burning, a good weights session burns more overall anyway.
Think about what you just said.
"I want lean muscle for sports"
What does that mean? Is mountain biking a sport where it's advantageous to show off big muscles? Nope.
For any sport, you use the gym to get stronger so you'll also be stronger doing your sport. Isolation movements don't build strength, but a good strength program like SL 5x5 will.
