thanks again for the info
cant wait for the UHD Stutter/juddering fix it should be out this week hopefully
then that will be my tv complete and full of awesomeness![]()
No problem mate ,they are great sets ,wouldn't change my E6 for anything
For HDR film viewing I've found the following looks good to me, can't comment on games. Try them and see
HDR standard mode
Oled light 100
Contrast 100
Brightness 50
Sharpness 10
Color 55
Tint 0
Dynamic contrast medium (personal preference here, do check out the others - off or low is too dim to me though).
Super resolution off
Color gamut wide
Edge enhancer off
Colour filter off
White balance colour temperature warm1 (warm2 is too green!)
Noise reduction off
Mpeg noise reduction off
Black level low
Real cinema on
Dynamic contrast works really well on HDR ,i was suprised![]()
Yeah it absolutely ruins the ISF modes though, terrible!
For HDR it just seems to punch out the highlights more without raising the black levels much at all, which means it looks nicer without looking unrealistic to me.
I haven't bothered with slides, what hasn't been seen can't bug me, not noticing any problems in content so happy just to carry on![]()
oh just because you did hahaha
As you can see the white slide is awesome and the near dark slide is fine also the line you can see in the middle goes away i was doing something on the pc just before i took the picture so left a temp image.....
but those look fine and i cant see anything in any content![]()
8. There is an outstanding issue with motion stutter in one very specific scenario, LG apparently have a firmware fix coming for it. The scenario where this occurs is UHD Bluray with HDR enabled. 4K HDR streaming is fine for me.
I would like to see them make a TV without speakers at all though, would lower costs and could instead focus on just the panel. I know this is technically a "Monitor" but I will ignore that.
sounds like a really good set apart from this one issue, relating to HDR 10 sources (according to the AVForums review from last week)
Hopefully LG will get it resolved, but tv is way too expensive to buy in the hope this gets resolved.
Even after having a Kuro for 5 years (best picture quality possible when it was new) Im still regret not having inbuilt speakers on occasion. Im not sure how much different the price would be either, probably wouldnt be as much as you expect.
Already resolved, see post above yours!
Unfortunately according to other reports it still isnt fixed (bariing in mind this isnt evident on all UHD discs in the first place)
