- 19 Oct 2008
Anyone know if a new 860w (or 851watt I think is the exact rating) is good enough for two 780 ti superclocks? I don't intend to overclock the cards any further.
Power Consumption GeForce GTX 780 Ti 2-way SLI
System in IDLE = 129W
System Wattage with GPU in FULL Stress = 617W
Difference (GPU load) = 488W
Add average IDLE wattage ~20W
Subjective obtained GPU power consumption = ~ 508 Watts
GeForce GTX 780 Ti 2-way SLI - On your average system the cards require you to have a 800 Watt power supply unit as minimum.
The boost will goto what it can safely cope with. The only downside is Nvidia don't want cards returned, so the boost is extremely conservative. I did a guide on how to overclock a Titan/780 but I am stuck at work till 2pm, but I will link it then if you would like?
Damn, that thing is loud
Alright so I set the power limit to 106%, and found I can get a stable 3D Mark run at +200 Core, +425 Memory. 3D Mark 11 benches at +250 core, +425 Memory but I guess it's not stable enough there for 3D Mark.
What do you reckon guys? is this a decent overclock or considered low compared to what you all are getting with these cards?
Yep thats good , The Ti overclocks pretty well , mines about the same as yours, the funny thing is i have always found that the reference cards always clock better than the Lightnings, Classifieds etc (On air), i don't know why this is and maybe i'm just unlucky.
My system only using 107 watts at idle...Power Consumption GeForce GTX 780 Ti 2-way SLI
