Anyone have any recommended videos for box squats? Reading through the article now but a video would be good.
Also what are people's views on front box squats - are they worth it?
The videos in the squat section are box squats.
Front box squats are also good.
The most important question, however, is why do you want to do them?
Here's the video.
So what I was doing wrong in this video is a rock forward to initiate the lift off the bench. On my next set I fixed it but didn't get a video. I will get a better one on Friday.
You've also got a fair amount of backwards momentum as you hit your box.
I'd prefer a box that was an inch lower as well.
1. No trainers....... Why??? I certainly lift with trainers and being a size 13, it won't be easy or cheap to find anything else suitable.
2. Upright rows to be avoid..... Why???
1. As stated in the OP, anything with a hard flat sole is suitable, so this doesn't have to be expensive. Trainers are rubbish, I only wear them when I'm not really doing any lifting. Not only are you creating an unstable lifting platform (Dear physio ball bicep curlers: no, this is not a good thing), you are also going to absorb a percentage of the force you deliver through your squishy heel.
If you've got weak ankles with poor flexibility, this is going to create all kinds of problems.
2. First and foremost, with any type of bar (sorry Morba
) you are at risk from being severely internally rotated at the top of the movement. The shoulder is extremely weak here, and this is where you're putting the most force through it. It's not a simple case of "just do them with good form", a high percentage of people CAN'T get their shoulders back into the right position at the top (see MWOD videos for shoulder internal rotation to see what I mean).
This doesn't stop huge numbers of gym folk doing them, even if they're experiencing pain. Side note: just because you're not experiencing pain, it doesn't mean you're not damaging your shoulders.
A good method of testing whether you have internally rotated shoulders is to ask yourself the following questions: Do you sit at a desk? Do you bench press? If you answered yes, then you probably have internally rotated shoulders (which ironically means you're missing internal rotation when your should is in the right place). The mobility thread is there to save you
There will be some people who can do these safely, but most people don't know
that their movement is bad movement so assume that they are in this group.
The bottom line for me is this: it's a risky exercise, and there are alternatives that do a better job anyway.
