Those look like lovely squats from the side, but from the back we can see how unstable you are in your hips and knees.Good news, they'd found the bands (red and green).
Blasted 2 sets of the glute exercises out before squats and 2 sets after as well as the mwod from the mobility thread:
http://www.youtube.com/watch?v=_Gwgm3s2EQ0
After all this I was able for pretty much the first time ever to break parallel by quite some way with bodyweight squats. My upper body did come forward horrendously but normally I would fall over even with this.
Definitely going the right way
Right the reason I uploaded this was to see whether I'm positioning the bar correctly for low-bar squats. To me they feel much less natural than high bar. It also felt like it was putting more pressure on my back to hyperextend when standing up and not in the actual squat. Wondering if I'm doing something wrong.
The 2nd video I threw in at the end just to see whether the bar position was correct - I was already knackered so form's not great.
Keep doing what you're doing and aim to slow things down slightly for a couple of sessions. Aim to be completely stable.
). Started off at 45 after warming up and kept adding until it got heavy.
Love to be able to get in to squatting again, time will tell
previous gym had large 15s, 20s and even 25s but this one only has 10s -> 20s.So a weak core is to blame for the rounding?
I think I'm not going to bother changing routine or anything yet, I'll stick with the current routine and throw in a lot more core stuff.
Should core stuff be at the end of the session? The only problem I forsee with that is that my core will be fried by then? Perhaps a separate core + hiit session is needed?
“Since the basic nature of correct ab function is isometric, the exercises in which the abs perform this function will provide exercises for the abs as well. This may seem childishly apparent, yet virtually every strength coach adds extra concentric/eccentric ab work to the program anyway. The thinking must be that just squatting, deadlifting, pressing, cleaning, snatching, chins, and barbell curls – all of which involve trunk stabilization as a critical performance component – do not provide sufficient ab work by themselves. I disagree.” -Rippetoe
I'm a noob but from what I've read it's more about hip mobility when it comes to getting your arse in the right place.
bum tuck = lower back rounding
