It is entirely dependent on how you feel.
If you are worried about injury (not "z0mg I could snap by adding 2.5kg o to the bar!" but "this is uncomfortable and this feels not great...") then back the weight off to something you are comfortable with. Training solo puts a lot of emphasis on how you - yourself - feel during your session, both under the bar and between sets.
If your form is ropey, then yes: better sorted sooner than later when the weights (and potential for injury) are greater. However, a tight hip/groin is not necessarily a sign of bad form, but could be just a tight/spasming muscle due to (very l) minor tearing or lack of correct agonist/antagonist balance in strength/stability.
TL;DR:
It might not be bad form, but getting checked out (whilst getting checked out, nomsayin'?) is never a bad thing.![]()
A quick question if I mayI've been working on my deadlift form however it's been difficult as my routine only includes 1 set of 5 reps every other day. Anyway my set felt really good yesterday but this morning my traps feel like they're on fire.
Is this normal?
Deads will develop traps. Just make sure you aren't shrugging them.
The King of the Deadlift (Delvis) is correct.
Also, do three sets (assuming Stronglifts?).
Finally, your traps are hurting... because you've never used them before. The lifts probably felt great because your back, core, etc. was nice and tight and doing what it was supposed to. So good work.![]()
Hi all, hopefully someone can help with the problem I've been having with squats. I've been struggling to progress with my squat. I assumed it was due to me cutting but I now know it is a form issue. There are two issues, firstly I'm pushing the weight through the middle of my feet not the heels which has resulted in me leaning forward. Secondly after reading reiyushin's log I've realised I don't engage my glutes at all.
I found a video explaining screwing your feet into the floor which keeps the knees wide and loads the hamstrings and glutes. I tried it this morning and definitely found it easier, the weight felt lighter and went up easier.
At what point of the squat do you squeeze your glutes? I found I could only squeeze when I was about half way up which helped lockout the squat. Is this correct or should I be squeezing my glutes at the bottom of the squat?
Cheers
