***Gym Exercise Guide, and Form Discussion/Feedback***
You might want to try putting the back through a series of flexion and extension as well as rotation frequently. Checking out yoga positions is a great option such as the cat, camel position (? - I don't know the actual name of the movement but people and the interwebs should know what that is!). One of my favourite back stretches is by having a broom or some for of light straight object on my traps and gently rotate from side to side. Once the back loosens up a bit I start to bend forward, putting the back through intentional flexion, whilst still rotating and go as low as I can go. I then work by way back to a standing positon and then proceed to rotating through extension by carefully leaning backwards and still rotating. After doing this sequence a few times all feels better. But this must be done really carefully, so start slow and stay slow until you get a proper feel for it.
After all of this I'd highly recommend doing the "Iron Cross" movement stated by Joe DeFranco and then the Crucifix stretch for multiple reps with each leg.
I love a good crucufic stretch me - and annoyingly I did loads of stretches last night after some light squats and as if by magic my back felt 100 times better this morning. I still am pretty sure that sitting oddly caused it both times but only in the sense that it aggrevated an already tight area, which is hugely helped by stretching. Doh.
Well I've just discovered a dysfunction I've had and never really noticed. My right glute doesn't engage and I'm using compensating muscles in my PC to lift weights. Which is why I've been having sticking points. I did some mobility tests and as I push my knee back (as if I was sprinting) on my right leg, the knee moves outwards rather than in line with my body. It just won't drive straight unless I put a huge amount of effort and care.
Normally if your glute is strong enough it should override the compensating muscles (i.e. you don't need to compensate).
It's annoying as I have a LOT of work to do to bring it back in, but I can concentrate on it at least and I've spotted it.
Lots of single leg glute bridges, walking lunges, split squats, box squats, single leg squats coming up! I need to ramp up this assistance work anyway. Won't be hitting any squat / Deadlift PBs before Christmas I don't think.
Do you have my email still Freefaller? I have some stuff to potentially try wake up your glute prior to training if you wanted me to share.
Sent a trust message :)
For info, what mobility tests did you do? they sound great / awful *delete as appropriate
Hard to describe without showing.
Here are some good examples:
http://breakingmuscle.com/mobility-...unction-2-common-problems-and-how-to-fix-them
http://breakingmuscle.com/mobility-...s-not-the-enemy-but-maybe-your-foam-roller-is
Hai chaps, another mobility question if I may. I've been doing a 2 week challenge set by my yoga teacher and her friend - it's essentially doing a different arm balance every day at whatever level you're able to do it at (beginner/easy version, more advanced etc) - and I've been able to do most of them pretty well so far. The one I failed at utterly I managed to do today by using a yoga strap to bind my arms. It's Peacock Pose which is commonly known as an elbow lever by the callisthenics/gymnast people.
Still pretty ropey as I need more core strength to straighten out but at least I can hover over the ground.
Anyway, without the strap, I simply can't get my elbows inside my body enough to stab them into my gut to be able to maintain the pose - they just slip out otherwise. I thought my shoulder mobility was good since I can do reverse prayer (prayer with hands behind the back), overhead squats, eagle pose and stuff like that but it's obviously not. What sort of things should I be doing?!
It actually makes me think of the front rack position as well, since that requires you to keep your elbows 'in' with palms vertical - in an ideal world - and that's something I still need to work on.
Not sure - over a typical week atm I do seal rows and pull-ups twice (one day 3-4x6-8, the other 2-3x10-12), conventional deadlifts triples for 4-8 sets once and sumo deadlifts 6's for 3-5 sets. Also RDLs twice a week (similar scheme to rows/pull-ups) as I guess you use your lats isometrically in those too.
I've noticed this as well when trying to do Wheel pose - it's very hard to keep my elbows from flaring out which makes pushing myself up off the floor silly hard as I'm in an extremely inefficient position.
Maybe tight lats?
Tight lats but probably rubbish external shoulder rotation.
Just tried the elbow lever just now and it is definitely hell on lats and teres M... But then the whole upper body, too! :D
A lot of the elbow lever is just balance (and a tight core) - although it's a bit tricky so hat's off to people that can planch properly. I guess that's what I need to work on then! Reverse prayer (see pic below) is internal rotation(?) so I've got one way going well but the other way is cack.
Today's one was even worse - the forearm stand - I used the strap again but it was a right 'mare.
Just balance? Your hands and arms are pointing the ring way, if they're not flexible or loose they will naturally try and turn out.
