Means your stomach is coming out and your lumbar curves in. It comes back to neutral as you hit parallel.
You seem to lean forward too, is this intentional?
My natural motion I believe. It was brought up pre-injury. I tend to fall backwards if I go further back
This is one of my older ones:Major bum tuck.
Been doing any ankle mobility?
Devils, look at what your doing with your hips at 0.18 as you get under the bar, and then at 0.24 after you have walked the bar out.
Your rotating your hips, backwards if that makes sense, and putting your back in to a far from neutral position.
Wait till Saturday and there will be plenty of people who can show you how you should be squatting.
Poor glute flexibility, poor hamstring flexibility, poor hip hinge motor pattern, poor core stiffness.
Over extending (sticking your bum out) will turn off your core.
Joking
So thanks.But you told me you where stretching your glutes and hams
Over extending won't help your back as well.
MOAR glute stretching needed, and you need to be more aggressive with your hammies.
If we get time on Saturday I will fix you with my healing hands...
As I say, just wanted to see how my overall form was after stretching for a few weeks. I haven't back squatted in months.Just reminded me to do some Glute stretching. At the moment I basically just ram a ball in to it.
Reply in the mob thread if it's more appropriateWhat else will you be doing?Reply in the mob thread if it's more appropriate
I'd say they look very easy for you.
Is your pains/aches stopping you going heavier? Or you just trying to 'perfect' your form?
ie since Injury.
