Delvis why do you give advice with such authority if you're not so sure?
I give advice on what I believe to be true.
If it is wrong or incorrect, I would rather someone points it out so I know for the future.
try not to let the bar roll around before the lift - on the 100KG attempt you roll it back towards your legs then lift instantly
. It's not the end of the world as long as you don't compensate position to move the bar, and that way you don't have to fanny around trying to work out how far away your shins are before you set up, you just get them on the bar when you are down there
. I'll say it again though this is only acceptable as long as there is no change in form because of it.Looking so much better there Deception, just one point really, you need to make sure you are driving your thighs into the bar at the top of each rep. I don't know if this will help you but it helped a friend of mine to tell him to tense his glutes and his quads as hard as he could.
That's what I do. It's not the end of the world as long as you don't compensate position to move the bar, and that way you don't have to fanny around trying to work out how far away your shins are before you set up, you just get them on the bar when you are down there
Then in some comps you see people walk up and throw it up in the air in less than 2 seconds including setup time
I'm a bar roller too, easiest way to bring the bar to your shins imo!
Deception, you spend too much time on the negative, I'd personally just slam that bar in to the ground. But then again, training in your own home I can appreciate if you'd rather not!
I will give that a go next time. When rolling the bar back, it just seems to help my form better and stop my hips rising instantly than what I did previously.I give advice on what I believe to be true.
But there is potential for any incorrect advice to be taken on board before someone else corrects it. This is bad, especially if it leads to an injury or something. :\
Edited in: It's not as if there is a lack of people on here with the expertise.
I'm guessing theres no issues in doing that, as people have their different setups afterall so hopefully someone more experienced can correct me
It's like a learner driver giving advice to others when there are advanced drivers around.
Perhaps you just need to reword the way you say things? I don't know how you can be so relaxed about potentially giving out bad advice.
Deadlift form progress
Start of feb 115kg
Today
The head issue was a lack of thinking, still to focused on getting everything else right.
I said keep your shoulders back? How is that back advice?
The rolling of the bar is a personal way to setup, I even said that.
It's a lot tighter than in the first vid mate and it's not arching as much either.Big improvements from everyone!
I think what you both need most now is practice. You both need a little more glute activation and drive, a little more stiffness in your torso, and tension on the bar before the reps.
Thanks Ice. Always good to know I'm heading in the right direction.
Well done too Syla, looks like we just need to hump the bars!![]()
