Help building a PC.
you should be able to connect multiple bluetooth devices to a computer.
i'm assuming your wireless kb/mouse is bluetooth too?
You got it yet? What are your thoughts
Yeah arrive about an hour and a half ago..... I'd say the SSD is an absolute must it's made such a difference. It's noisy at startup but pretty quiet after that. You can overclock it to 3.7 with Ryzen Master and it's stable. So overall a very nice little system for the cost IMHO.
How are you getting on with it?
Wow you waited a long time.
So do you just plug the sad in then?
Glad you are happy with not. What is overclock it mean with Ryzen Master.
Yeah took it's time getting here.
So Ryzen Master is AMD's software that allows you to overclock the CPU, it's all point and click ( you can download it from http://www.amd.com/en/technologies/ryzen-master). The overclock makes a fair bit of difference so if you ever feel you need a little more power then it's worth a shot. Yeah the SSD took about 5 minutes to install (I put it just next to the mechanical disk at the back near the PSU), but then took about 25 minutes to clone the disk :(. Now it really does perform well tho, so super worth it, I've only put a 120GB Integral drive in mine but again makes a huge difference.
ssd is the single biggest upgrade to improve QoL for a pc user
kinda, plug the ssd into a spare sata port, and then you'll need to reinstall windows on it, and then configure bios to boot off the ssd. then you can wipe the 1tb hdd and use it for storage.
Impressive frame rates in games so far (~60 on high settings) which for a £400 PC is pretty decent. At the moment it seems like the RX560 is limiting the R3 which is surprising to me.
