Caporegime
The gaming K5 and the 7 are the best ones.
4yr warranty, better sound solutions, better rgb options etc.
Theres no problem or hassle with a NVME drive unless I suppose you are using an ancient OS.
It is so big you need to have ram without stupidly tall heatsinks.
As you were considering the relatively modest but classic 212 cooler have you considered the NH-U14S Ultra-Quiet Slim CPU instead of the monolith that is the D14.
There's only a few degrees difference in performance and it's half the size - and unless you're going for an extreme clock it will still keep your CPU frosty and quiet.
I mention it as I have a similar monolith strapped to my present system - Thermalright Silverstone. Yes it keeps things cool but it's a PITA to work around and clean (although the Noctua is easier to fit and fans are easier to move). But, I personally feel, the performance does not warrant the hassle or the weight of massive heatsink - unless you're going to be clocking your system to absolute nth degree.
If you're going for a straight forward clock then the NH-U14S Ultra-Quiet Slim CPU will do the job - superior to the classic 212 but not such a hog when it comes to space and you can use whatever blingy memory that you want (although I personally like the plain stuff).
But, don't get me wrong, the D14 is in a class of its own - along with the BeQuiet - for performance but the fact you were considering the 212 you may want to take a look at the NH-U14S as it's a great compromise between size and performance.
sounds perfect, I won't overclock so the size compromise is great for me
Onto the fractal r5, the case fans seem okay, should I keep them or change them?
BeQuiet or Super Flower, as you're looking for a quiet setup, within the budget you can afford - 750w ideally unless you plan sli (which i personally think is a waste).
But any quality brand Corsair/seasonic/evga will do the job - I've personally always bought Corsair but will be moving to BeQuiet for my next build due to forum banter.
