For radiator fans - remember its about static pressure fellas. XS have an exhaustive review about 120mm 1850 GT's outpacing a shed load of 140mm fans on a 140 rad.
Not sure about the vipers as they can be very loud - I can't stand too much fan noise, so if I do get Akasa 140mm I will probably go for the Apaches as they have -4db in noise but only -10CFM. (Vipers are 110CFM @ 26db, Apaches are 90CFM @ 22db).....
Still not sure - My 1450RPM GT's were just about bearable noise wise so I might just stick with them on a couple of 120>140 brackets. 280 rads are defo the way forward though as they seriously outpace the 240 rads and come very close to 120.3 cooling levels, oh and they are nowhere near as restrictive as the 240's either.
Fan controller to keep the vipers under control noise wise - when benching turn up, normal use turn down???? I realise that fan choice at 140mm is severely limited. Static pressure is indeed what we seek, but finding a 140mm that provides high static, but reasonable noise is proving verry difficult.Think I will start with the vipers with my fan controller and see how the noise/performance ratio works - I too do not desire high fan noise as this defeats to a certain extent the benefit of watercooling in the first place.
Lets see how we go.
Mark
