Man of Honour
- 5 Jun 2003
- Falling...
Are you making sure you've got the right indentation in the .yaml file? It's REALLY fussy about it.
This worked great thank you.There a few different ways of doing this. Cloudflare or DucKDNS seem the most popular.
The Easiest Free Way To Do Home Assistant Remote Access!
I have covered quite a few different remote access solutions for Home Assistant, either through port forwarding or setting up VPNS but recently, it has emerg...youtu.be
I switched from a Conbee II this week to a Sonoff Zigbee 3.0 (the later ‘E’ model). I found with my Conbee when I hit over 50 devices, occasionally I had small issues with commands not being sent. One example being the 4 GU10 Hue bulbs in the kitchen, I would often find one or two still turned on after they’d all been turned off. It’s not happened since switching but it’s only been a couple of days so far.
How would I know? There was a few times after replacing the yaml file it wouldn't let me restart HA. So I copied and pasted Katies and all is fine.
It's possible if you have no data in that output - or it could just be null.Does it need some "Solar now" data to make it start? meaning it won't work untill tomorrow?
Weird - oh well, glad it's working - I wonder if it was just waiting for the first set of data then! Oh well, sounds like it's fixed!Gave up and went to bed last night.
Got up this morning and the intergrations button was asking for my API key again to re authenticate. Did that and it's working. However, looking on PVOutput it has uploaded my generation for yesterday and today using the same data.
Progress! and something I can look to filddle with hopefully.
Re: entities, yes. I can see those and they all show data that matches what my device apps show.
Unfortunately configuring CloudFlare has nuked my PSA Car Controller for my Pug's battery level, lol.This worked great thank you.
Hello! Yes you've got it right, so the intuitive bit is working!Finally got hold of a thin client and a zigbee stick (sonoff) and have got HA setup on the pc.
I've added various integrations (Hue, Wiser heating, Meross smart switches, Tuya devices etc and they've been added to the overview dashboard and things seem to turn on and off etc using the switches in the dashboard just fine.
However I'm trying to set up a tradfri remote to turn on two of the meross smart switches and I just can't get it working. I feel like it should be simple but I guess I must be missing something because I can't get it to wotrk.
What I figured was to add an automation. The trigger being the remote button being pressed and the action being the device (Meross smart plug switch) set to turn on. But nothing happens and I odn't know why. I feel like I must be missing someghin simple or that the way to do it is less intuitive than I was hoping.
Can anyone help me get to grips with this or at least get one thing working just so I can see that it will work because at the moment I feel like its going to be a huge headache.
Do you mind posting a screenshot of your automation? (That'll be the quickest way to diagnose how you've set it up)
Stating the obvious, but have you paired your tradfri button with HA? Do you know that it works etc?
Super - let's start simple then and work out if the problem is happening before the automation or after.Firstly, Yep I've got the remote paired in HA and it seems like it's working, when I press buttons I get entries added into the device log as shown:
This is my automation:
And in the yaml view:
Ah, sorry - should have remembered that, had the same challenge. It's an issue with the IKEA gear (ie they have a funny way of triggering on and off - in effect it's a toggle, so it doesn't work well).Right, having done this about a dozen times and it not having worked at any point, I've just tried it and the light came on as it should do... No idea why it hasn't worked previously, I literally did exactly the same set up!
I've just changed it to toggle the smart switch and now it's doing what I wanted, turning it on and off. I have no idea why it's not worked previously.
